2007 clk bluetooth puck confusion !!
Subscribe
May 16, 2012 | 03:04 PM
I really need some help. I have a 2007 clk 350 with the command nav system that is prewired for bluetooth. I was finally able to find the wiring in a secret compartment in the back of the center console. There are two pigtail adapters pictured below and a small slot that the wires were rolled up and stuffed into.
My questions are:
what puck do I need to get?
what are the 2 separate pigtails for? All the pucks with tails I have seen only have 1?
does the puck go into this compartment behind the compartment or into the console itself?
Is it going to have to be programmed in any way with the fiberoptic system? the car has/had the telenav option.
thanks for the assistance.
Reply 0
May 16, 2012 | 05:04 PM
You've got quite a bit more than a puck to buy, friend. Search "puck cellguy bluetooth" and you should find some info. Figure $600-$700.
Reply 0
May 16, 2012 | 11:11 PM
Yep, Eddie is right - that's just the "prewiring" which comes with pretty much every CLK. It is literally just "wire". If you do decide to spend the money on the interface hardware, ask to get the version that can be totally hidden in the passenger floorboard so you can keep your center console for storage.
Reply 0
Subscribe
Currently Active Users (1)
