SRS issue..
Old Jul 25, 2012 | 05:45 AM
Np55's Avatar
04 W211 E55 AMG
SRS issue..
Hi guys just thought I'd ask around to whoever has been through the SRS issue. I have a problem were everytime my passenger seat is moved significantly my SRS light triggers off. I know it's due to the shortness of the wires between the unit and the seat sensor coming loose and being faulty.. Anyway not sure of its true as I've heard multiple answers but if the SRS light comes on does that cut off all the airbags or just for that specific section (in my case, the passenger seat airbag)
Old Jul 25, 2012 | 06:00 AM
SUECHAS's Avatar
sl
Went to dealer on Monday for SRS light being on. They told me if the light is on, the airbags will not deploy
Old Jul 25, 2012 | 09:02 AM
Np55's Avatar
04 W211 E55 AMG
As in all airbags? I was told only the affected section will be disabled.. I was told either a faulty cable or passer side seat sensor pad and if that was faulty only the passenger side airbag would be inactive but the rest would be still active ..
Still a safety issue though.. More money to fork out now :| lol oh well safety first I guess.
Old Jul 25, 2012 | 10:54 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
My driver's side did this. I was able to remove the seat back and manipulate the wiring harness to gain more slack and secure the connector. FYI, all SRS errors have to be reset - they don't "go away" like transient ECU errors.
Oh, and the SRS system knows what's wrong - the entire system is not disabled because of one fault like this one. Of course if the fault is more than just one squibb circuit,such as a defective control unit, then that might disable the whole system.
Old Jul 26, 2012 | 07:41 AM
Np55's Avatar
04 W211 E55 AMG
Ok thanks for that.. Well I'm guessing it might be my seat pad sensor as I had a passenger sitting down and the seat was not moved in anyway and still triggered off.. It seems this problem is common and happens to the left chair (when inside the cabin) yours being your drivers chair and mine being my passengers as mine is RHD.. Will get this fixed though.. Can't compromise on safety
Old Jul 26, 2012 | 11:59 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Get someone with SDS to check the codes - it will tell you exactly what is triggering the error.
Old Aug 3, 2012 | 06:54 AM
NardoNZ's Avatar
CLK55 AMG
I had my SRS light on after i took my COMAND unit out... after putting it back in and resetting thee car the light went out... by itself
Old Aug 3, 2012 | 11:07 AM
Np55's Avatar
04 W211 E55 AMG
It's annoying because you get it reset with the star diagnosis then it just comes back on again after someone sits down .. Btw very nice car. I done the same conversion myself (clk 55 front end to the clk 63) and it really makes the carole aggressive. Only thing though my car is a humble 320 lol not the beastly 500 or amg.. One day though ..
Old Aug 3, 2012 | 09:37 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Probably because you had the upper control panel disconnected and switched on the ignition (maybe to test the radio?). If the passenger airbag indicator light on that panel can't be detected, it triggers an SRS error.
Old Aug 3, 2012 | 09:42 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
That could be the weight sensor on the seat, but it still could be the sidebag wiring harness. That wiring harness in my seat was so tight, I think just going over a bump could cause it to come disconnected from the connector. Like I said, get the specific code checked with SDS and it will tell you for certain.
