how to get rid of low coolant warning
Old Aug 26, 2012 | 02:33 PM
jp196400's Avatar
2005 CLK 500
can someone tell me how to get rid of the low coolant warning light that keeps popping up on my dash?
I changed my rad and ever since its been coming up.
the coolant level if full.
Old Aug 26, 2012 | 05:12 PM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
Try remove the sensor and clean out the build up residue. It work for me when I have the same issue 10 yrs ago with my Slk 230.
Old Aug 26, 2012 | 09:48 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Also make sure that you don't have a problem in the wiring harness. It's wired in series with the windshield washer fluid pump. If it is unplugged, you get the low coolant error (I know, this doesn't make sense, but it's just some sort of electrical anomaly in the system).
Old Aug 27, 2012 | 11:09 AM
Nealgobert's Avatar
Rentals
Mine did the exact same thing when I changed the radiator. Turns out it was due to air being trapped in the system. I just squeezed the lower hose with the cap off to release the air, topped off the fluid, and the problem went away.
Old Aug 27, 2012 | 11:51 AM
jp196400's Avatar
2005 CLK 500
Great advice guys, as soon as it stops raining I'll get out there any see if I can fix it.
