Please check my VIN for Balance shaft issue?
Old Jun 6, 2014 | 10:24 PM
  #701
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Originally Posted by cbp24
I typed an incorrect VIN above. Please check: WDBTK56F37F222490. Thanks.
That has M272 #563634 - it's beyond the range for balance shaft trouble.
Old Jun 7, 2014 | 04:45 PM
  #702
astrobike's Avatar
2006 Mercedes E350 4Matic (W211.087)
Hello Rodney,
Which year models have less problems/issues, after 2005 Mercedes-Benz cars? Would you recommend specific models which have lesser problems/issues?
Some models have balance shaft problems, some models have SBC issues, some models have transmission issues, etc...
I think that MB's effort to lower their manufacturing costs as Toyota/Lexus and others do is one of the causes that have brought the realiability issues. IMHO, MB must do their best to keep their traditional virtue and reputation at least in the mechanical/hardware robustness.
Old Jun 7, 2014 | 10:43 PM
  #703
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
For the W209 CLK, I'd suggest a MY2008 or MY2009. The balance shaft issue affects all models across the board using the M272 and M273 engines through mid-MY2007. This includes V6 and V8 xx230, xx280, xx300, xx350, xx450 and xx550 models. TMY2005 SLK250 was the first with the M272, then other models followed in MY2006. Also, the early 7GTRONIC 722.9 transmissions tend to be more problematic. It was introduced on the MY2005 SLK350, and all MY2005 V8s. It went brand-wide in MY2006. Note these is one exception - the MY2005 W163 ML did not use the M272 even though it was badged ML350 (it used a 2/7l version of the M112). Also, the MY2005 ML500 did not use the 722.9.
Old Jun 10, 2014 | 12:11 PM
  #704
rmjones383's Avatar
2008 c300
WDDGF81X78F104426
2008 C300
Old Jun 10, 2014 | 03:47 PM
  #705
bowen003's Avatar
2009 E-350
balance Shaft
Thanks Rodney!!!
Old Jun 12, 2014 | 12:37 PM
  #706
Kevin9664's Avatar
2011 E550 Cab & 2015 ML400
WDBTK72G67T080437
2007 CLK550
Old Jun 12, 2014 | 12:57 PM
  #707
JLZSAN's Avatar
c230 sport
can someone check a vin # for balance shaft issue?
I am looking at purchasing a c230 sport 2007 and would like to know if the car is in the ranges that have the balance shaft issue? VIN# WDBRF52H37F927411. If you could respond asap it would be greatly appreciated as I am in the middle of making a deal on this car as I type. thanks for your time.
Old Jun 12, 2014 | 11:20 PM
  #708
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Originally Posted by Kevin9664
WDBTK72G67T080437
2007 CLK550
That one has M273 #96931 - beyond the problem range.
Old Jun 12, 2014 | 11:21 PM
  #709
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
That has M272 #596019 - it's beyond the affect range.
Old Jun 13, 2014 | 10:04 AM
  #710
JLZSAN's Avatar
c230 sport
Thumbs up
Thank you
Old Jun 14, 2014 | 01:02 PM
  #711
sirics's Avatar
C300, ML 320, 190E
Rudeney,
2006 ML350 - 4JGBB86E76A093151
Old Jun 14, 2014 | 09:10 PM
  #712
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
4JGBB86E76A093151 is a MY2006, so it's going to be in the affected range. M272 engine #273538 confirms that is is.
Old Jun 14, 2014 | 10:05 PM
  #713
sirics's Avatar
C300, ML 320, 190E
Thanks. Do you know if such repair would show on a carfax? I just bought a 2006 ML350 and am wondering if the repair has been performed already. Thanks.
Old Jun 14, 2014 | 11:35 PM
  #714
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It is doubtful that Carfax would give enough details. I would check with our dealer - they can pull a VMI and it would definitely show on that if ti was done at a dealer. Just remember that only a small percentage actually fail.
Old Jun 21, 2014 | 05:47 PM
  #715
mguerrero's Avatar
w215 - CL55 w/stage III
anyone know of a good Benz VIN decoder?? I need to find out what options are on a new to me car I'm buying - specifically need to know if it has BOSE audio Thx!
Old Jun 21, 2014 | 08:25 PM
  #716
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Here's one - it's in Russian, so use Google Chrome to access it and it will translate for you:
http://www.auto-parts.spb.ru/cat/cat...&client=dr2000
If that doesn't work for you, post the VIN and I'll look it up for you in my copy of EPC.
Old Jun 24, 2014 | 01:43 PM
  #717
mikats's Avatar
2006 c230
balance shaft issue repair
after getting dealer price, decided to bite the bullet and replace balance shaft myself.
The car had no running issue, but would not pass emission inspection, due to the balance shaft issue. It has become a project car, so with the savings, I don't mind buying more tools.
2006 c230 sport
As I just removed old shaft, the teeth were complete gone, the shaft was not in time but there was no indication of a balance issue, ran very smooth.
Old Jun 24, 2014 | 09:54 PM
  #718
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Interesting that the shaft was not rotating, but the engine was smooth. So, how bad was the job? how long did it take?
Old Jun 25, 2014 | 09:11 AM
  #719
martinln65's Avatar
citroen
Vin
Can you check this for me? Thanks heaps
WDB2093542F242444
Old Jun 25, 2014 | 10:28 AM
  #720
saltycajun's Avatar
C230
Please Check
Please check this one:
WDBRF52H87F917750
Thanks!!
Old Jun 25, 2014 | 11:10 AM
  #721
iyadr's Avatar
CLK 280 2007
Hi rudeney
I am planning to buy a clk280 model 2008 and I was wondering if it you can check my vin code and give me your recommindation?
I would really appreciate it
My vin#: WDBTJ54H78F248079
Old Jun 25, 2014 | 04:09 PM
  #722
jayz's Avatar
2003 S430 4Matic
Hi Rudney
Looking at 2008 GL450
Vin# 4JGBF71E78A343948
with 72K - car fax says camshaft position sensor replaced at 43k
is this the same as balance shaft gear or that gear is going bad?
could you check VIN to see if engine is affected?
Thanks! JayZ
Old Jun 25, 2014 | 10:12 PM
  #723
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDB2093542F242444
You have M272 #743551 (beyond the affected range)
Old Jun 25, 2014 | 10:14 PM
  #724
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBRF52H87F917750
Thanks!!
That has M272 #575892 - beyond he affected range.
Old Jun 25, 2014 | 10:15 PM
  #725
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Originally Posted by iyadr
Hi rudeney
That's a MY2008, so no worries - M272 #811951.
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
