Please check my VIN for Balance shaft issue?
Rating: Thread Rating: 8 votes, 5.00 average.
Old Dec 3, 2015 | 11:31 PM
  #1226
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
No - you have serial number 922504 - that's well beyond the problem range (ending with 468993)
Old Dec 7, 2015 | 12:04 PM
  #1227
suprtran's Avatar
BMW
Hello,
Please check for any issues common to this '06 CLK500:
WDBTJ75HX6F188967
Thanks.
Old Dec 7, 2015 | 11:14 PM
  #1228
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The MY2006 CLK500 uses the M113 engine - no worries there. Only the M272 V6 (xx230, xx280, xx300, xx350) and M273 V8 (xx450, xx550) would have the "balance shaft" problems
Old Dec 7, 2015 | 11:17 PM
  #1229
suprtran's Avatar
BMW
Thanks Rodney.
Anything I should be concerned about with respect to it's 7-speed transmission?
Old Dec 7, 2015 | 11:52 PM
  #1230
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The early 722.9 transmissions are definitely more trouble-prone. The most common problem is needing a new conductor plate (common, as in most all need this). It's about $1500, and a dealer-only job.
Old Dec 13, 2015 | 04:12 PM
  #1231
Maffu313's Avatar
05 C55 AMG|04 C32 AMG (traded)|07 E350 - 4Matic|08 S450 - 4Matic|08 R550 - 4Matic|05 Boxster S
Hi, I've been looking all over the engine bay for the engine code, but can't seem to find it. So can someone please decode my VIN for me and let me know if my engine is within the affected range?
Vehicle: '07 E350 4matic
VIN: WDBUF87X87X217801
Old Dec 13, 2015 | 09:58 PM
  #1232
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBUF87X87X217801 has M272 #480110 - It's beyond the balance shaft problem range.
Old Dec 17, 2015 | 04:02 PM
  #1233
Maffu313's Avatar
Thanks! that's a big relief
Old Dec 19, 2015 | 12:44 AM
  #1234
2002c230coupe's Avatar
c230 2002 coupe
VIN WDBTJ72H17F214183
Is this affected? 2007 clk550. Also should I spring for a 2008 model if it means avoiding problems with the transmission?
thanks for all the help
Old Dec 19, 2015 | 01:16 AM
  #1235
c230 2002 coupe
i just checked. I think this car is within the affected range. http://www.mercedesmedic.com/check-m...y-vin-m272273/
the engine number is 087217 which is older than 088611 which means this car will be a headache to own. Thank God for these posts, dodged a bullet there.
Old Dec 19, 2015 | 11:07 PM
  #1236
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yes, M273 engine #87217 would be in the range for potential failure.
Old Dec 22, 2015 | 06:28 PM
  #1237
TTR's Avatar
TTR
R129 SL500 & W140 S500
Could you check mine please?
WDBTJ56H29F261515
Thanks!
Old Dec 22, 2015 | 11:30 PM
  #1238
RNajarian's Avatar
Veteran: Air Force
2020 E 350; 2022 E450 Coupe; 2005 Porsche Cayenne; 1975 Porsche 911 Carrera 3.0
Having trouble finding/decoding my vehicle
May I also ask if someone can tell me if I am affected
2007 CLK 350. WDBTJ56H57F218977
Old Dec 24, 2015 | 12:46 PM
  #1239
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBTJ56H29F261515
Thanks!
No worries with a MY2009 - MY2007 is the only year than needs a check by VIN/engine serial number. Before that year, all M272/M273 engines are "in the range" and after that, all are "out of the range".
Old Dec 24, 2015 | 12:50 PM
  #1240
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
M272 engine #527779 - beyond the problem range.
Old Dec 24, 2015 | 03:54 PM
  #1241
RNajarian's Avatar
Veteran: Air Force
Rudeney
Thank you for your Herculean efforts
Kindly change your Member Profile from MBWorld Guru to MBWorld God
Old Dec 26, 2015 | 02:26 PM
  #1242
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
"Guru" is bad enough! And looking up these engine serial numbers is easy - I can use my local copy of EPC, or the online "Russian" version (http://www.auto-parts.spb.ru/cat/cat...&client=dr2000). Then you get the engine number and compare it to the range in the TSB:
http://benzbits.com/BalanceShaftTSB.pdf
Old Dec 28, 2015 | 08:47 AM
  #1243
jayr7309's Avatar
2007 sedan c230
can you check minr too on my 2007 c230 Please
WDBRF52H87F927307
Old Dec 30, 2015 | 11:42 PM
  #1244
TTR's Avatar
TTR
Thanks for checking! I appreciate it!
Old Dec 31, 2015 | 11:02 AM
  #1245
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBRF52H87F927307
M272 #594640 - beyond the balance shaft trouble range.
Old Jan 7, 2016 | 03:02 PM
  #1246
paulie737's Avatar
450sl
Hi Rodney,
Any chance of checking on this VIN? Clean carfax. 2007 Mercedes C230 sport sedan. CEL code P015 and I will be replacing magnets on camshaft timing module as this seems to be the fix for this code but I am concerned about balance shaft failure and interested if the engine is in range. If it is, I will take car to Mercedes to see if the repair was done for the TSB.
VIN. WDBRF52H27F860364
Old Jan 7, 2016 | 03:07 PM
  #1247
paulie737's Avatar
450sl
Thank you!!!
Old Jan 7, 2016 | 10:36 PM
  #1248
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Originally Posted by paulie737
Hi Rodney,
You have M272 engine #438120, which is in the range for potential balance shaft failure. If you are having the "Scenario #2" failure of the camshaft solenoids, I doubt that thee engine has had the balance shaft replaced, since most dealers replaced the solenoids along with the balance shaft. But, don't panic! Balance shaft failure is rare. Even though the engine is in the range, only a small percentage actually fail.
Old Jan 8, 2016 | 01:26 AM
  #1249
paulie737's Avatar
450sl
You have M272 engine #438120, which is in the range for potential balance shaft failure. If you are having the "Scenario #2" failure of the camshaft solenoids, I doubt that thee engine has had the balance shaft replaced, since most dealers replaced the solenoids along with the balance shaft. But, don't panic! Balance shaft failure is rare. Even though engine is in the range, only a small percentage actually fail.
Thank you Rodney!! One last question. Would an engine oil sample analysis give an indication of pending bearing shaft failure? Thank you!
Old Jan 9, 2016 | 09:36 PM
  #1250
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I guess it could, but you'd need to compare it to an engine run the same way, same miles, and without balance shaft failure. Honestly, I would not worry about it. The number of engines ailing doesn't even show as a blip on the car review sites and magazines.
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
