Remove side marker
Old Sep 19, 2012 | 10:14 PM
mis3's Avatar
2004 CLK320
Remove side marker
I have a malfunction of side marker lamp.
I have the bulb but I am not sure how to remove the side marker cover. Do I pull it out from the front or from the back? Any help is appreciated.
Old Sep 19, 2012 | 11:26 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Use a plastic tool and press on the front of the marker to move it toward the rear of the vehicle, while prying outward until it pops loose. Once you get it out, you'll see the rear of the marker is a plastic "spring clip" and the front has two tabs that snap into the opening.
Old Sep 20, 2012 | 12:51 AM
togaclk55's Avatar
CLK55
I just pulled on one of the sides until it came out
Old Sep 20, 2012 | 03:02 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
If you live in a hot climate, be very careful. The housing crack very easy if you pry it out.
Old Sep 20, 2012 | 10:28 AM
mis3's Avatar
2004 CLK320
Bulb replaced. Thanks.
The connection looked a bit rusted, maybe I will have issues later.
Also, I tested the bulb before putting back the cover and I noticed the bulb got hot quickly. Is this normal?
Old Sep 20, 2012 | 09:46 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yes - it gets very hot. It often melts the plastic socket.
Old Sep 21, 2012 | 02:32 PM
mis3's Avatar
2004 CLK320
Thanks. This sure eases my concern.
