Need help with Headlights!
Old Sep 27, 2012 | 02:40 AM
devious1's Avatar
2004 clk500
For the past 2 weeks,I've been noticing that my headlights were not aligning properly when I get in my car at night. when I get home,I've reset the lights and then they would level together then,the next evening,I will start the car and watch the leveling and then the right headlight will be either too high or to low. then I would have to adjust the right side to match up with the left every other day! is there any suggestions or any way I can keep this from continuing?
Old Sep 29, 2012 | 12:39 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It sounds like a problem in the headlight leveling servos. Unfortunately, those can't be repaired individually - you have to have a whole new headlight assembly.
