CLK 500: Check coolant level
Old Oct 1, 2012 | 03:57 PM
Motsekim's Avatar
CLK 500
Are there known problems with CLK 500 cooling system. My CLK coolant needs to be topped up every few days. I suspect that there is leak in the cooling system. Where should I start with my investigation?
Old Oct 1, 2012 | 10:04 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
If it's not leaking from a hose or the radiator, then it's going into the combustion chamber which would probably be a bad head gasket. Do you get a lot of water vapor from the tailpipe?
Old Oct 2, 2012 | 02:55 AM
Motsekim's Avatar
CLK 500
Thanks Rodney, I do not think I get water vapor from exhaust.
Old Oct 2, 2012 | 10:58 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Water vapor at start-up is normal, but not after the engine is fully warmed to operating temperature. Check it with a paper towel held behind the tailpipe - if it collects water, then you are losing it through combustion.
