W209 CLK500 WITH CLK55 MOTOR AND TRANS...
04 SL55 AND 05 CLK55
Ok, this is my project so any info before I start would be awesome. I just recently picked up a 2004 CLK 500 coupe with 145k miles and its running great with no issues! Today I bought a 2005 CLK55 amg vert hit from the front but runs and only has 59k miles. Just to put things in perspective, both cars cost me $7500 combined. The vert is a salvage title and the coupe is a clean title with no sunroof! Rare. I want to build a track toy and make it as light as possible and the sunroof less CLK would be a great start. I want to basically swap all the goodies over(sway bars, brakes, exhaust, factory nav, and obviously motor and trans)but not sure if the drivetrain is plug an play. I here plenty of assumptions but no direct answers. I assume the engine and trans is a bolt up swap and the ecu's and tcu's could be swapped. I might need a reprogam for the key if the ecu has an immobilizer system. Any factual advice would be welcomed. I will keep eveyone informed on this project as well. Thanks guys.
W203 slightly modified
If you visit Motorwerks in Houston and speak to Sunil Patel, your questions shall all be answered.
He is trading but his website is momentarily down for no good reason. His forum name is Sunman (king of mods). When you finish the project let us know if you are selling the engine and gearbox. Might have a buyer in Australia.
Should take a couple of days to finish this transplant. Though, when you see Sunil's 55K powered W203 you may wonder if 55 is enough power.
Wow sounds very interesting, sorry I don't know the answer to many of your questions but please keep us updated on your project, cant wait too see how it turns out! Good luck!
Thanks guys for all the pointers. Since I already purchased the 05 vert, I plan to use all of its upgraded oem parts(brakes, sways, wheels)but I will purchase a coilover kit and have the the car corner weight balanced. Keep in mnd that the 05 came with the 6 piston front and 4 piston rear calipers with larger rotors. I plan to reduce the weight by only 200lbs. I could do more but still plan on driving it on the weekends. Simple weight reduction path as done before(my s2000 and e46 m3)would be light weight battery, carbon bucket seats wrapped in leather, exhaust mods, carbon inner trunk panel to remove spare holder and f&r rebars. 200lbs less with 05 brakes will be just right! I have my own shop and dedicated mechanic so labor costs are not a big concern and I get parts at wholesale so overall cost won't be crazy. I feel that a 3400lb CLK55 with 400 crank hp(330-350whp)will be a great daily driver and weekend track car. I'm also trying to keep the cost as low as possible and possibly make money off the parts that will not be used. My total on both cars is at $7500 now, plus labor and additional parts, I'm looking at $11k or less. I'm going to keep everyone up to date and I will also dyno every mod.
I've been looking at those topspeed headers for our cars and they look like decent kleemann shorty header replicas. My topspeed replica headers for my e46 m3 gained 13hp on the dyno so I'm ok with China made knockoffs. I also plan on getting the ecu flash, sl55 intake, pulley and 300 cell cats. I'm going to stay away from cams for now and see what can be done with the other mods plus weight reduction. I think you guys will like the end results. Stay tuned.
I slapped on some Top Speeds and wrapped them they are worth it, no Dyno charts to tell a diff, but she moves so much smoother, especially mid to higher RPM's, good for the money, good fit too!
