Replaced motor mounts...
Drivers side motor mount started leaking last week so I replaced both motor mounts and tranny mount. Both motor mounts were collapsed and tranny mount had a small crack. I used E55 motor mounts because I heard they were stronger. We dropped the sway bar and lifted the engine from the bottom to wiggle the mounts in and out.
CLK55 AMG
I have no idea tbh... I was thinking like with suspension, the softer, the smoother the ride... It might be completely different with these mounts... please enlighten me!
MBworld Guru
The part numbers for the CLK320 vs. CLK350 vs CLK500 vs. E55 are all different. Here are some motor mounts:
CLK320 = A2032411113 (L&R)
CLK350 and E350 = A2112402617 left, A2112402717 right
CLK500, CLK550, CLK55 and CLK63 = A2202400617 (L&R)
E55 = A2202402717 (L&R)
E63 = A2112403117 (L&R)
E320 = A2302400117 (L&R)
The E500/550 is more complicated - they have four different mounts based on chassis numbers. Also, the mounts on the W211 are different for 4MATIC models. Anyhow, I just found this interesting. My guess is that the actual mounts will fit across all of these engine/model combinations, but they are just tuned differently. I am not sure I'd use different mounts. The science of vibration isolation is not as simple as "softer = smoother". You have to consider harmonics, and how much you want the engine to move before stopping it.
What's up Louis? Is that a C63 Rims Rep on ur sig pics? I just ordered a set of C63 Rep . Will post pics when I have them installed . I'm sure it will looks good on my car because my color.
2015 E400 CAB, 2010 Jeep Compass, 2009 E350 Sedan
Andy.
They are OEM AMG wheels came off a 2007CLK63 Cab had them for a few months now. They are pretty nice I love they look. Sorry about the thread hijacking back to the regular programing
2009 ML350
Rudney, maybe you can enlighten me a bit. On the Parts.com diagram for the CLK350 they have left and right Front mounts, but they also list a single part for a Rear mount. I just need one of those correct?
I'm planning to update most all the rubber under my hood soon, seeing as I'm just breaking 90k miles. Also in my service it is recommending I do all my spark plugs at 91k. Do you recommend I go ahead and hit anything else under my hood?
Thanks in advance, you guys!
MBworld Guru
You should be able to do this without a lift. One thing about the W203/W209 chassis is that it has front rear center jack points. There is a large rubber block under the engine on the front that can be used as a jack point, then you place jack stands behind the front wheels on the front side jacking blocks. On the rear, you can jack against the main differential housing (use a block of wood or rubber to protect the housing) and then place jack stands in front of the rear wheels on the rear side jacking blocks. You should now be able to do the job. Keep in mind that you need to lift the engine, which requires removing the exhaust. The engine is to be raised from the top - not jacked from the bottom or you may damage the oil pan.
