Humidity Problem İn My 2008 Clk
Old Dec 6, 2012 | 03:41 PM
Yalin's Avatar
W209
Hi guys.
İts winter in europe. İt has been raining alot in my region nearly a month and soon i might see moderate snow ( maybe no snow at all but still very cold till may) There is alot of humidity in the car even i use the windshield fog removing in the a/c ( sorry if you guys call it something else) Every 5 to 10 mins i have to use it again which becomes annoying as its very noisy.
İts my first coupe and never had any problems like this in my previous cars but i heard from friends that this was common. İ checked the doors insulation rubbers for both on doors and inside and it seems that there was leakeage on both sides as you can see water drops on the sides
All the rubber seems ok no wounds or cuts etc... Should i check anything else? Something chronic about it? Or should i only replace them at it will solve the issue??
Thanks in advance.
Old Dec 6, 2012 | 09:01 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I find this to be a fairly common problem - both my C240 and CLK550 do this when it's humid and cool outside.
Old Dec 6, 2012 | 09:05 PM
Yalin's Avatar
W209
But there is water drops on the mercedes bagde - on both sides... Few of my friends mentioned about the smell in the car two. My noise is useless hehe
İ will properly check it tomorrow or at the weekend.
