2004 electric problem
Old Jun 1, 2015 | 06:35 AM
LOB's Avatar
LOB
CLK 270CDi
I suspected that was the OCP module that was sending "trash" messages to the bus since I can't reach that module through the obd diagnose tool.
I will check that can bus terminal. Do you know if the ocp module can line is connected to that bus terminal? How can I know if the bus line isn't interrupted between some can bus terminal and the ocp module?
Thank you very much
Old Jun 1, 2015 | 11:40 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The CAN bus to the OCP could be shorted or disconnected. I'd start by removing the OCP to check the wiring connections there. I am not sure if the OCP CAn bus goes to that terminal, or not - I'd have to study the WIS wiring diagrams. There is also another CAN bus terminal attached to the under dash panel on the driver's side - i.e. the black plastic panel where the hood release is located.
