CLK240 Engine swap?
Old Jan 5, 2013 | 02:05 AM
13allsofsteel's Avatar
W209 CLK240
CLK240 Engine swap?
Hey guys, I am new here , and yes I tried to do a search before I posted this.
I was wondering whether it would be easy to swap a M112 engine for a M272 engine in my 2004 CLK.
How easy would it be to mount the engine and also the electronics?
I found a practically free CLK280 engine that works and was just curious //
Cheers
Old Jan 5, 2013 | 08:35 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
I would imagine that as long as you have the complete wire harness & ECU, it should be straightforward since they are both CLK offered engines.
Old Jan 5, 2013 | 03:07 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The M272 and M112 V6's are very similar and are drop-in replacements (assuming the replacement comes with its own belts, accessories, ECU and wiring). Note that you should check the serial number on that M272 engine (we can look it up by VIN in EPC for you) to make sure you aren't getting one with potential balance shaft problems.
Old Feb 20, 2020 | 09:25 AM
psotnic's Avatar
CLS55 AMG, CL65 AMG (W216)
Old Jan 20, 2021 | 11:23 PM
Omar Jamal's Avatar
clk 240
Clk 240 engine swap
My clk 240 2005 (w209) runs on the 5g tronic transmission, i was thinking of swapping my engine with the clk 350 engine but it runs on the 7g tronic transmission and i dont think mine can handle the torque, am i right? And would it be possible to perform a c32 amg engine swap? I know a clk320 swap is easy but it’s not worth it since it doesnt offer that much power. If you have any other ideas for my clk 240 let me know im new to this.
Old Jan 21, 2021 | 07:45 PM
dzmitry's Avatar
2023 E450 AT, 1996 S420, (sold) 2004 CLK320 Convertible (v8, 6 speed)
m272 swap (350) would be much more complicated than m112k (c32) since your engine is m112 and it's very possible , take a look at my thread https://mbworld.org/forums/clk-class...0-v8-swap.html, I swapped 5.0 into my clk320.
