'04 209 command replacement
Old Jan 27, 2013 | 10:31 PM
Jaydeath's Avatar
2013 SL550, 2011 E550 Cab, 2013 E350 Sedan
Hey all, I'm actually a service advisor at a Benz dealership and own an '04 CLK 500 but to be honest I don't know much about the aftermarket industry. Does anybody know a plug and play system that I can use to replace my D2B command with?
Attached Thumbnails '04 209 command replacement-393954_10100101691316745_516394672_n.jpg
Old Jan 28, 2013 | 01:44 AM
Clkboi's Avatar
CLS550 4Matic
Nothing plug and play i have coem across yet. Some manufactures claim to be but can't answer the fiber optic questions. I put an Appradio 2 on my 06 CLK and there was a lot of wiring done by BestBuy to get it working.
Old Jan 28, 2013 | 11:09 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Your car probably has the Bose option, which means there is no analog audio wiring in the dash - it uses the D2B fiber optic ring to send audio to the Bose amp in the trunk and it converts to analog for the speaker-level outputs. There is no plug-and-play option. If you want to go aftermarket, it's not too hard, but here are the things to know:
1. The dash will hold a double-DIN unit. You will need a trim plate adapter, but they are readily available. As long as the new unit is not exceptionally deep, you should have no problems there.
2. You can get a "plug and play" wiring harness fore the vehicle (many eBay sellers offer a kit with the harness and the faceplate). However, it is missing any connections for accessory power an illumination because the factory system gets these signals through the CAN bus. Also, it will have wiring for the speakers, but the vehicle's harness will not have those so you will need to run your own analog wiring to the trunk.
3. To get signals for accessory power and illumination, you can tap into the wiring harness feeding the ashtray - it has both. Another option is that there are some CAN bus adapters that give you steering wheel control and also offer those signals. Some also offer a signal for reverse gear in case you want to add a backup camera.
4. You will need to replace the Bose speakers. First of all, they are 2ohms, and few amps can drive that. Also, without the specialized equalization from the Bose amp and head unit, they will sound terrible.
My advices: Replace the head unit with a nice aftermarket touch screen NAV, run low-level analog wiring to the trunk, remove the Bose amp and add your own amp in the trunk, replace the speakers.
Old Jan 28, 2013 | 04:19 PM
megacrazy's Avatar
CLK55 W209, CL63 W216
There doesn't seem to be anything plug and play.
Get a CAN adapter, that will give you steering wheel controls etc. Get 1 or 2 amplifiers (depending if you want or have that center speaker) and run wires to the head unit. The Bose speakers will sound just fine. You can retain all of them including the sub as long as you get the right amps.
