CLK-500 Xenon lights (2003)
Old Mar 13, 2013 | 11:36 AM
lanceharobr7's Avatar
2003 CLK 500
(I suck at cars)
The left front Xenon light sometimes works and sometimes doesn't. Occasionally it just takes a while to warm up.
My mechanic tells me both lights must be replaced at the same time. Am I being screwed?
Gracious Thanks
Old Mar 13, 2013 | 12:36 PM
Drummajorc's Avatar
W203 C320, W208 CLK 320, w209 CLK 500
Xenon headlights gradually loose light output and also change color as they age, as such, when changing bulbs people usually recommend changing both at the same time, since if you only changed one the other one would be a different color due to the fact that it is old, it would also have lower light output. If your bulbs haven't been changed in several years, I'd go with the mechanic and replace both of them, but if they were both recently replaced then I would only replace the one bulb, which is probably faulty.
Old Mar 13, 2013 | 01:30 PM
2003 CLK 500
Thank you good sir. *
nm
