WTB Stone interior door panel
Any suggestions where to find a used drivers side interior door panel in Stone. This is for a 2006 CLK cab but I think the door panels for 2006-09 are all the same for coupe and cab.
Thanks.
Thanks.
MBworld Guru
I don't believe the coupe and cabriolet panels are interchangeable due to the different airbags - the coupe has door-mounted side bags, the cabriolet has seat-mounted head/thorax side bags.
Rodney is correct - they are not the same. A coupe panel may fit, but you'll have that football-shaped SRS button on the door where the airbag is. The convert has no SRS label on the door. Ebay is your best bet.
Thank you for the replies to date.
Ebay has some nice gray panels but not Stone. Patience and hopefully it will surface.
