Ambient Temp Sensor always shows a higher temp
Old Apr 29, 2013 | 11:32 AM
ricardovasco's Avatar
CLK 500
Hi all. I realize my car always shows a higher temp. I mean, if the external temp is 22C it shows 28C..etc. Do you guys know what it is?
Regards
Ricardo
Old Apr 29, 2013 | 09:15 PM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
I had body work once and the sensor was too near the engine bay after. Could be a minor thing.
Old Apr 29, 2013 | 09:24 PM
CLK 500
Its possible. Is it easier to access or I do need any tool to check it?
Old Apr 29, 2013 | 09:49 PM
cd5negro's Avatar
2009 clk 550
I have the same problem. my car said the other day that it was a hundred and fifty degrees Fahrenheit.
Old Apr 29, 2013 | 09:55 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The sensor is located on the front bumper, right side, lower grille, near the foglight. If you can't see it protruding through the grille, then that could be the problem. Just remove the plastic shroud under the bumper to access it and put it back in the right place.
Old Apr 29, 2013 | 10:10 PM
CLK 500
Thanks Rudeney. I will check that tomorrow. Do you think I need to replace it or its closer to a hot stuff ? I mean, it is working but with 3..4..5C degrees higher than the real temp.
Old Apr 30, 2013 | 12:14 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
My guess is that it has become dislodged. I will say that the sensor is not going to be 100% accurate. Mine seems to read a few degrees (Fahrenheit) higher than my wife's Jeep. I haven't checked the CLK vs. the C.
