Chirping Sound CLK350
Old Jul 2, 2013 | 04:20 PM
amandasosa's Avatar
CLK350
Unhappy Chirping Sound CLK350
For the past 2 days in the morning when I turn on my car I hear a moderate sound of chirping coming from my engine. After I drive it for about 20 minutes it is gone.
What could it be?
Old Jul 2, 2013 | 09:19 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Does it sound like it's coming from the dash, or the engine itself? On the very front of the engine is an air pump that runs right after start until it reaches a certain temperature. This electric motor can chirp when its bearing start to go bad. If it's coming more from the dash, it could be the ventilation fan. When its bearing go bad, it can also chirp.
Old Jul 3, 2013 | 06:17 PM
Patton001's Avatar
2006 CLK350
Also could be an idler/tensioner pulley. They chirp when they start to go bad.
Old Jul 3, 2013 | 07:34 PM
mecca281's Avatar
W222 s550 , BMW 535i 15’
I also have the same chirping sound accompanied by an electrical like ticking.
The chirping I believe is coming from a bad bearing as the fellas have stated, but it could also be the bearing on the coolant pump. Good luck!
Old Jul 3, 2013 | 10:56 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
If you suspect it's a pulley bearing, and easy way to narrow it down is to (carefully!) spray some WD-40 onto the pulley bearing as it runs to see if it quiets down (try not to get it on the belt, though).
