aux input 2004 clk 320
2004 clk 320
New guy....here goes. I have a 2004 CLK 320. I am pretty certain I have an audio 10 system. Is there an easy way to add an AUX input? Or even bluetooth.
(Seems pretty straight forward for those with audio 20 but nothing for audio 10)
Looked around but it seems like some of the forums are a bit dated.
I have added a pic of the radio.
Look forward to any help or advice.
Thank you.
Thank you.
MBworld Guru
About the only way to do it with that radio is to wire the AUX input into the low-level inputs inside where the cassette player head is connected. There are instructions on this on The Internet and maybe even a company who will do it for you if you don't want to tackle the tedious job yourself. An alternative is to replace the head unit with a more modern aftermarket unit. If you don't have Bose, it's relatively easy. If you do have Bose, you'll need to do a little extra wiring to get analog lines into the trunk and bypass the Bose amp.
