HID bulb or ballast problem?
Old Sep 17, 2013 | 01:44 PM
Rogue-CLK's Avatar
2016 C300 4Matic
Question HID bulb or ballast problem?
Every now and then my right or passenger side bulb or ballast fails or errors. It tells me the light bulb is out but when I refire or restart the car it works just fine again. How much do they each cost? (1)Bulb only and (1)Ballast only, and both if I do anything should I replace both bulb and ballast or just the broken 1?
Old Sep 17, 2013 | 05:55 PM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
depending on how old they are you might get a slight different color output...if you can afford it i would go ahead and change both ballasts. they're only about $100 a piece and the bulbs you can get cheap as long as they're D2R.
Old Sep 17, 2013 | 06:00 PM
Rogue-CLK's Avatar
2016 C300 4Matic
The problem side (passenger side) isn't white as the other side. Is that a key in figuring what might b wrong? Price is at the dealer correct? Or it's all the same price? I guess I can start with just the bulb and go from there.
Old Sep 17, 2013 | 06:18 PM
maverik259's Avatar
then its most likely the ballast going bad...and i correct myself they're D2S bulbs...
Just search the forum for ballasts and you'll come up with a parts number. Ebay is a good place to look as well
Old Sep 17, 2013 | 06:33 PM
Rogue-CLK's Avatar
2016 C300 4Matic
Alright thanks figured it was d2s lol
Old Apr 24, 2014 | 02:45 PM
Rogue-CLK's Avatar
2016 C300 4Matic
Changed only the bulbs (both) no ballast. $30 for a pair, works fine 8000k tho :/ not blue but not completely white looks more like 6000k bulbs.
