Ok to get CLK550 even though it's the 1st yr of M273?
http://benzbits.com/BalanceShaftTSB.pdf
If you post the VIN of a candidate car, several of use here have access to EPC and can look up the engine serial number.
Oh,and one other thing - the earlier 722.9 transmissions were more problematic. There's no specific serial number range for problems, but the later models are more reliable. it might be worth it to pay a little more and get a MY2008 or MY2009 - those are 99.999% certain not to have "balance shaft" problems and will likely have a more reliable, later-built 722.9 transmission.
If you are on a tight budget, look at a CLK500, but only up to MY2004. The MY2005 introduced the 722.9 transmission. An alternative would be a CLK55 AMG - they have aolsid engines and only used the 722.6 transmission. Performance is not quite up to the CLK550, but better than the CLK500.
