Vibrating at over 40. Problem is not balancing. Wheel hub going bad? Hubcentric ring?
Now before i even put any spacers on ive had this vibrating issue from the get go. Alignment also needs to be done but i doubt that will effect the vibrating.
The wheels have been balanced 2 times now and inspected by a wheels only professional who said the balancing was fine. Now this is what he told me. He said the wheel hubs in the front are going bad because he could tilt the wheels i would say roughly and inch or 2 while the car was in the air and the wheels were on and that may be causing the vibration.
Problem being, i didnt have such a vigorous vibration with the oem 18 inch amgs i had on the car which were also heavier before i put these on, granted there was a small amount of vibration. I always figured it mustve been a balancing issue so i didnt pay much mind as it didnt effect the ride much
Now question is. Can these "bad" wheel hubs cause this vibration at higher speeds? I would assume if they were bad the car would be vibrating all the time? If so, has anyone got it done before or had a similar problem? is it covered under warranty? The car only has 49500 on it, seems like the wheel hub shouldnt be going bad till at least 100,000. I had a c230 that went to 200k without the wheel hubs going bad.
Ive also checked the hub measurement on both the wheels and the hub. They both are 66.56 mm so i dont think hubtrensicity is the issue
Also, if he can tilt the wheels an inch or 2 while the car is in the air then...ummmm hahahaha yeah. I would look for much larger problems...tie rods hubs etc.
If the hubs were bad I'm sure you'd hear some sort of noise at speed.
