fault finding errors. car will not speak to diagnostic tools
Old Nov 14, 2013 | 01:20 PM
mrpwstringer's Avatar
w209
Recently When a diagnostic tool is connected to my w 209 2003/2004 it will only speak to the engine systems .
It will not connect to the alarm/seat restaint/ insumentpanel/ etc.
It has been suggested by the garage that the ingnition switch is faulty this is about £324 from Mb
I have had a series of odd events over the last few weeks.
Firstly the car would not start . I charged the battery (i suspect I caused this lot to happen as i did not disconnect the battery) when it did start the instrument consul was completely blank. two days later the instrument panel reappeared but showing an seat restraint fault . then it was a nice afternoon and I lowered the hood it would not raise again (on another thread)
Anyone whose mechanical/electrical expertise is current and not based in the 1970's got any ideas ? (ps all spellings are dyslexic and my own)
Old Nov 14, 2013 | 08:34 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It sounds likely that the voltage fluctuations caused some problems. I assume this is Star Diagnosis you are trying to connect?
Old Nov 15, 2013 | 03:03 AM
w209
Yes this is star Diagnosis which my garage (auto shop) is trying to get to connect. This car one of the very early w209's
Old Nov 15, 2013 | 03:26 AM
mawais's Avatar
Mercedez Benz Actros
Diagnostic Code Help
My contact details are gracy28@gmail.com i possess an Actros 2,3 truckthat has developed a few fault which is not comprehendable. I possess the Star diagnostic System aswell. The veh details are:-
VIN: WDB93028222149615
Engine No: 541.926
Model: Actros 2,3
The Software Disgnostic facility of Diagnstic equipment was initially not functioning and providing an Error message Switch on the Ignition (Although Ignition was Switched On). Subsequently the facility started. Fault Codes observed from the star diagnostic system application to Actros veh are:-
Code Text Status
01313 Relay K4 for function "Terminal 15" is missing or doesnot switch on Current
01413 Relay K3 for function "Terminal 15" is missing or doesnot switch on Current
0A036 No Comm is possible with Con Unit BS Brake Con Current
0B123 Failure of Veh CAN Bus Current
Old Nov 15, 2013 | 04:10 AM
w209
hi i do not know if this is relevant or not but my auto shop/garage in uk are telling me that star will not connect with the systems on my car and are suggesting the ignition switch is faulty. I intend to have a new one fitted . it occurs to me that if you have intermittant connection to star may be you have a similar problem Kr peter.
I am absolutly no help on the codes! I will follow the thread and let you know the out come of my new ignition switch
Old Nov 15, 2013 | 05:08 AM
mawais's Avatar
@ above ...
Will be waiting
Old Nov 15, 2013 | 10:53 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
if you are using SDS an getting errors, double-click on the error and you'll get steps to help you diagnose the problem. These problems do wound like "EZS" (EIS) issues.
