Locate trim part/part # for 2005 CLK320 W209 Cabriolet
2005 CLK320 Cabriolet
I am trying to locate a replacement trim piece but cannot find it in the parts explosions on the web parts store sites. It is the bezel(?) trim cover for the license plate lights. It frames the license plate lights and other things up under there. It is black and has two plastic squeeze clips, one at each end of the part that go into holes on either end of the light frame assembly.
When I look up the parts associated with the trunk lid I can only find the black trim piece that is inside the bottom of the trunk lid where the little finger pull is located. The part I seek is exterior, not interior.
Any suggestions or ideas? My piece has one of the clips broken off. I will repair it if necessary, but a new one, if less than about $40, would be simpler and more permanent - most likely.
Thanks.
Thanks.
Well, I finally found a part number and it looks like the darn thing is $100. So, I will try to repair it first and then will probably have to replace it at some point. Amazing how expensive these parts are.
