Are CLK 350's known for intake manifold (cracking?) problems?
Yes, plastic does break, but it's not a common problem for the manifold housing itself to crack on these engines. A slightly more common problem is that the plastic flaps and levers break. When that happens, you may be able to fix it with glue or "welding", but it really is best to replace the entire assembly. You don't want broken "parts" getting sucked into the throttle and engine.
Seems like such a small thing that broke, but the entire intake chunk of aluminium had to be replaced.
I think it might have broke when my engine was misfiring due to a back ignition coil.
Might have caused the engine to vibrate too much and snapped the plastic.
