Removing Rear Armrest
MBworld Guru
I checked the WIS documentation, and it's not very detailed, but it appears that after lowering the armrest, there are some release latches on either side of the rear pivot point that you actuate with a screwdriver. Like I said, it's not detailed enough that posting it would help, but they show a screwdriver inserted into the hinge area, so I assume there is some sort of spring-loaded or plastic clip release in there.
_n.
