CLK500 in snow?
Old Nov 25, 2003 | 09:22 AM
Nebraska99's Avatar
CLK500 in snow?
This will be my first winter with my 500. Could someone tell me how the 500 handles in light snow (4" or less).
Thanks.
Old Nov 25, 2003 | 03:46 PM
Eich's Avatar
2010 ML350 GAS 4Matic
Fairly awful - just like you would expect a powerful, rear-wheel drive, wide-tire car to behave. Winter mode and active handling helps but can still get dicey. You can probably get away with adding a little weight to the trunk if you drive on mostly level streets. If you have any hills to navigate, I'd look for another mode of transportation or find more aggressive winter-type tires.
Old Nov 25, 2003 | 06:03 PM
rmklaw's Avatar
2004 CLK 320 and 2004 Porsche Cayenne
CLK and Snow
I have a 2004 CLK. Definitively does not move in snow. Wheels like to spin. Just ordered a set of Pirelli winter tires and rims from Luke.
Old Nov 26, 2003 | 01:45 PM
WannaBeAMG's Avatar
i would think a good set of winter tires would make the car quite mobile in winter. i see plenty of rear drive cars (modern sport sedans and coupes with all the fancy stability and traction aids) around that either mount all-season tires or winter tires for winter and they get around just fine. keep in mind in MN we get some of THE nastiest winters in the continental US.
never underestimate the difference a good winter tire can make. check out some of the testimonies over at tirerack.com for the winter tires. youll find many people with simialar cars are amazed by how well thier car got around with winter tires.
Old Nov 26, 2003 | 03:33 PM
ChiCLK500's Avatar
Just to add my $.02, I just ordered a set of Bridgestone Blizzak LM-22's from tirerack. They'll be mounted this weekend, work pending.
It's my understanding that performance tires (like our Pirelli Pzero's) are not only terrible in the snow, but also do not grip well when the temperature drops. So just because it's dry out (e.g. no snow) doesn't mean the tires will grip properly.
Kind of sucks because this was a $650 expense I didn't see coming as my salesperson told me when I bought the car that it had all season tires on it. I should have verified this statement before signing the bottom line.
Old Nov 27, 2003 | 04:18 AM
WannaBeAMG's Avatar
Originally posted by ChiCLK500
It'* my understanding that performance tires (like our Pirelli Pzero'*) are not only terrible in the snow, but also do not grip well when the temperature drops. So just because it'* dry out (e.g. no snow) doesn't mean the tires will grip properly.
you are correct and thats a very good point. something i think many people dont realize. winter tires remain far more pliable in freezing temps than do either all-season or summer tires. and therfore grip better on dry roads as well as snowy ones.
ps: excellent choice of winter tire, blizzaks are sweet for winter.
Old Nov 27, 2003 | 11:57 PM
x15jq's Avatar
Out of curiosity, do 16 inch whls work on the 500? I noticed the rotor was quite large, and on my W208 320, I got 4 blizzacks ready to go, but for the 500, im not sure what to do. Will 16's fit the front whl?
Old Nov 29, 2003 | 12:53 PM
ChiCLK500's Avatar
I had my Blizzak's installed yesterday morning, but it seems to me that there is much more road noise than with the Pzero's and the ride is a little bit harsher. I was driving on fairly smooth roads with the temperature about 35 degrees. It could have been my imagination though.
Old Nov 29, 2003 | 01:30 PM
x15jq's Avatar
what size is the snow tires u got? Did u go 16 or get 17's. 17 inch is real expensive i think for snows, u want the narrowest tire possible. Im not sure if 16 fits it tho bc of the frpont brake.
Plz advise
Old Nov 30, 2003 | 09:51 AM
WannaBeAMG's Avatar
ya most snow tires will give you increased road noise, probably due to all the small sipes. though i wouldnt think the ride harshness would increase. i would double check your tire pressure to make sure its correct.
Old Dec 4, 2003 | 11:37 PM
rmklaw's Avatar
Snow Tires
I just received from The Tirerack a set of snows for my 2004 CLK. Pirelli's 210. 225x45 17 Front and 235x45 17 rear on AMG rims. I will install them this weekend and report since Denver is expecting snow this weekend.
By the way, great service by the Tirerack and quick shipment.
Old Dec 8, 2003 | 06:43 PM
Mikalish's Avatar
2010 C300 4matic
Did you have the tires installed by one of Tirerack's installers in your area? How much did you pay for mounting and balancing?
I contacted my MB dealer and they quoted me a VERY high price for the Bridgestone Blizzak LM-22's, so I'm trying to look for a cheaper alternative and Tirerack looks like the way to go.
BTW my car came with Pzeros also. The car handled great with them until it got colder. Now the car picks up all the seams and patches in the road and the handling has become somewhat nervous. It's fine on smooth roads though. I thought it might be an alignment problem, but I had the service department check it out and they said the alignment is perfect. My guess is it's the Pzeros.
Michele
Old Dec 9, 2003 | 07:27 AM
04CLK500's Avatar
I installed the LM 22's just a week after i bought the car (about a month ago). The handling is great, it hasnt snowed much here in Toronto (as yet), but the tires sure do thier job in cold weather. I'm happy with the choice I made.
Old Dec 9, 2003 | 09:49 AM
ChiCLK500's Avatar
Michele
I had the tires installed by Discount Tire as they are close to my parent's house which is where I had the tires delivered. Cost was $120 to mount and balance 17" Blizzaks.
It hasn't snowed in Chicago yet, but I'm happy with the cold weather handling of the Bridgestones. The only thing I'm not happy with is they are an ugly set of tires. Takes away from the clean lines the car normally enjoys. But hey, I can live with it.
ChiCLK500's Avatar
Michele
BTW, how much is your dealer quoting you?
Old Dec 9, 2003 | 09:24 PM
rmklaw's Avatar
Winter tires
I got my Pirelli 210s Snow already mounted on AMG rims from Tire Rack. 24Hrs after install on the car we had a good snow in Denver. Tires perform FANTASTIC. Felt more like a front drive car. Great traction in snow and ice. In dry the tires are smooth and feel just like my hi performance OEM. Great choice by TireRack.
Old Dec 10, 2003 | 02:48 PM
Nebraska99's Avatar
rmklaw...thanks for the report..
Do they have a much different appearance from the stock pirellis P zero's?
THanks.
Old Dec 10, 2003 | 06:57 PM
rmklaw's Avatar
Pirellis
A little higher profile. But you need it for the snow.
Old Dec 10, 2003 | 09:34 PM
Mikalish's Avatar
2010 C300 4matic
The dealer quoted me $1145. I also got prices from two local garages, both where $950.
Michele
Old Dec 22, 2003 | 03:07 PM
CLK500K3K4's Avatar
2003 CLK 500, 2004 allroad quattro
get good winter tires. try Goodyear Eagle Ultra Grip GW3. and let us know how they ride in the snow. i'm from CA, i wouldn't know anything about driving in the snow.
Old Dec 24, 2003 | 03:40 PM
rocky's Avatar
2004 Audi S4, 2003 CLK 500
Maybe you should consider a all wheel drive vehicle as a second car for snow
Old Dec 24, 2003 | 04:38 PM
CLK500K3K4's Avatar
all wheel drive - makes good sense
have you considered the audi s4? or any of their quattro equipped model?
Old Dec 24, 2003 | 06:15 PM
rmklaw's Avatar
Pirellis Winter
So far my Pirellis 210 winter tires on 17" wheels are outstanding. I have driven on snow and ice and they handle better than a front whell drive car. In dry conditions they really stick and have not noticed any harsher ride than my Michellins or any noisier. Good job TireRack.
