some help
Old Mar 25, 2014 | 02:46 PM
nick2265's Avatar
2003 CLK 500
some help
i am getting a malfunction on the check coolant level and check washer fluid level both are full any suggestions 2003 CLK 500
Old Mar 25, 2014 | 10:05 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The wiring harness that for these two sensors has them in "series" so if one is unplugged, it triggers both. Check the connections. You may need to remove the front fender shroud extension ahead of the front driver's wheel to get to the washer fluid reservoir and its sensor.
Old Mar 26, 2014 | 07:21 AM
nick2265's Avatar
2003 CLK 500
thanks
will try today i will let u no
