How do i fix a leak from the antenna?
Old Apr 16, 2014 | 12:16 PM
ninsei's Avatar
2007 clk 550
Hi. i noticed a leak inside the rear roof liner of the car and the outside antenna is a bit loose. how can i tighten it up, or should i just try to squirt some silicone under the rubber boot?
Old Apr 16, 2014 | 10:43 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
When installed, the antenna has adhesive that stick and seals against the glass. If it has to be removed, it is supposed to be replaced. I would try either silicone, or some of that "leak seeking" windshield stop-leak sealant.
