Flushing brake fluid?
I have been using EZ-Bleed for years. It uses the spare tire pressure and a brake fluid plastic bottle to pressurize and force spent fluid out the bleed fitting.
I now use a pancake air compressor to supply the 17psi. Works great. Just make sure you do not run out of fluid. Air may tough to remove if it gets into the master cylinder and lines.
http://reviews.halfords.com/4028/321158/reviews.htm
Thanks,
Zill.
