Keyless Go
Old Jul 1, 2014 | 01:57 AM
kstokes01's Avatar
2006 Clk 350 Convertible
Question Keyless Go
I have a 2006 CLK350, while driving the other day using the keyless Go, the car shut off on the expressway, I pulled over and placed the key in the ignition and it cranked right up. Recv no lights or warnings. What's going on?
Old Jul 1, 2014 | 08:44 AM
Yidney's Avatar
2008 CLK550 Cab
Are you saying that you tried restarting the car with keyless go and it would not start? Has it started using the keyless go since? Need more facts.
Old Jul 1, 2014 | 12:15 PM
kstokes01's Avatar
Keyless Go
The car starts fine with keyless Go, it shut off while I was driving. When I pulled over and put the key in, it started right up. I am concerned that the car shut off while driving without the key in the ignition. Hope that makes since..
Old Jul 1, 2014 | 01:50 PM
Yidney's Avatar
2008 CLK550 Cab
It makes sense, but since you titled the post "keyless go" I figured you thought there was some problem with the keyless go, and since you said you put the key in I figured you had tried to restart it with keyless go, but it would not start. But it sounds like it would have started, but you used the key instead. I'm betting the issue is not related to keyless go at all, and it would have stopped even with key in. Possibly a failing cam position sensor. Others will chime in.
Old Jul 1, 2014 | 02:30 PM
kstokes01's Avatar
I have been hearing a lot about cam sensor lately, is that a common issue with this cars?
Old Jul 1, 2014 | 10:56 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
If the car shut off with no MIL (check engine light) illuminated, then it's not a "camshaft" issue. It could be a bad crankshaft position sensor (CPS) as they can be flaky when it gets hot, but usually the car doesn't start until it cools down. And the CPS seems to be less of a problem with the M272/M273 engines.
In your case, did you get any messages on the MFD related to the key? If not, I doubt this has anything to do with KeylessGo. If it happens again, try restating with the Start/Stop button. If that doesn't work, but the key works in the ignition, then it may be a KeylessGo issue. Maybe the battery int he SmartKey is bad and needs replacing (but that usually results in a message on the MFD).
Old Jul 1, 2014 | 11:10 PM
kstokes01's Avatar
No lights came on, the dash goes completely black, no warnings, no noise. The car cranks right up when cranked with the key. Is there a kill switch on this model?
Old Jul 1, 2014 | 11:12 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
No, the "kill switch" is the Drive Authorization System, and it works the same regardless of whether it was "authorized" via KeylessGo or the key in the ignition switch. Again, I ask: When it does this, does it or does it no restart via the KeylessGo Start/stop button?
Old Jul 1, 2014 | 11:17 PM
kstokes01's Avatar
I haven't tried the Keyless Go when it happens, I always use the key when it happens.
Old Jul 1, 2014 | 11:21 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
If it happens again, try the start/stop button. If it works, then the problem has nothing to do with KeylessGo. I'd suspect CPD failure.
Old Jul 1, 2014 | 11:25 PM
kstokes01's Avatar
I purchased the care two months ago, it had happened twice
Old Jul 1, 2014 | 11:26 PM
kstokes01's Avatar
I will try your advice and keep you posted. Thanks guys for the help.
Old Jul 2, 2014 | 08:40 AM
Yidney's Avatar
2008 CLK550 Cab
As Rodney said, next time use the button, but before you do that, look for messages in the screen in the speedo. Rodney, what does CPD stand for?
Old Jul 2, 2014 | 10:49 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Oops! My stupid typos! I meant CPS (crankshaft position sensor).
