Things to Check
Car is in pristine condition and is truly a garage queen. 38,xxx miles, it is fully loaded with almost all options for that model year.
I'm friendly with an MB technician who has said that the 500 v8 and the 5 speed transmission is pretty much bullet proof in terms of reliability (expect for a wire from the transmission that may leak tranny fluid which is resolved with a replacement).
Anything else that you guys have experienced over the years and would suggest I checkout? Even though the car is low on mileage - at around 11/12 years old I assume things may need maintenance/changing due to age?
Thoughts/Suggesstions? I think it's a great deal @~10k.
http://forums.mercedesclub.org.uk/sh...42&postcount=3
Another common problem (and also an easy fix) are leaky valve/head cover gaskets.
I'm stoked about getting this car for just a bit over $10k. At only 38k, the vehicle drove like brand-new. The body and paint was in perfect condition, just some very minor swirl marks which can be removed easily with a good detail job. It even had factory bi-xenons which I was surprised to learn.
The car-fax was clean and confirmed what my MB tech friend said regarding vehicle service. Always dealer maintained and always recommended maintenance has been performed. Many parts that would need to be replaced simply due to vehicle age were already taken care of (bearings, struts, lubrications, etc).
How urgent would you say the radiator should be replaced along with a tranny fluid flush and change (as well as the transmission wire replacement).
Is there anyway to check how "contaminated" the tranny fluid is with coolant? I think these transmissions were designed for lifetime fill, so I'm not sure that there is an easy way to check.
