Suspension / 35mm Offset. Noise ?
- are these supposed to be so tight?
- im working on buying Bilstein HD Sports from a member and dropping. Considering the stock have the groove at the wheel bend. Will the new one act the same? It seems the Billsteins are straight.
- Has anyone come across this issue ?
- IF you have, will i need to add some spacers? If so what type is best and how large do i need to go in mm?
Any help is appreciated.
CLK500 - Cabrio - 2004. Stock Suspension.
