No Audio In 2008 CLK350!
My first post and am new to this forum.
I recently bought this car from an MB dealer in Florida. It had all I wanted minus iPhone interface and blue tooth. I searched this forum and other things and found that the mCar interface was the best...so I bought it.
I went to install it through the removal of the CD changer in the glove box. The instructions, however, stated to remove the Head Unit (HU) as well.
I first began to remove the HU without actually removing the wire harnesses from it. I could basically see the block of harnesses and three antennas. I then began to remove the CD changer.
After removal of the changer I removed the OEM plug adapter from the FO harness and replaced it with the mCar adapter. I spliced the OEM power supply and ground to fit the mCar unit. (Red/Blue Battery, brown ground).
Alas, nada! I emailed the mCar folks from their website and surprisingly got a call a few minutes later...on a Saturday. They were helpful but could not explain why I had the following problems:
- No Audio from the sound system.
- Lost Sirius (MOST doesn't recognize that it's there.
And after reinstalling the CD changer, the MOST doesn't recognize it.
I know there is power to the Unit (the changer) and that the input FO line is working (red light goes on and off).
I tried a multitude of things like opening and closing the car door (saw that on You Tube) to regain audio. I Reset the MOST (or COMAND) system using the front panel controls. I also disconnected the battery for over ten seconds.
As of this morning, the COMAND system recognizes the NAVI, AM/FM, iPod interface, singe CD player). There is no Audio whatsoever nor does it recognize the CDC (CD Changer).
I know it's something silly but beyond me right now so I need some help that will hopefully prevent me from taking it to the shop.
Help?
And thanks in advance!!
Rich
(01 SLK320, 08 CLK350)
Cheers!
Rich
Rich
And that's a good lesson - always check the simplest things first.
