How does one remove and replace the rear spoiler ?
Old Aug 2, 2014 | 07:35 PM
ninsei's Avatar
2007 clk 550
Hi. Is it really just taped on? I want to remove it, paint it black, and put it back. Is it just heat it up a bit, pry it off, remove old tape, use new tape. if so, what is the right tape to use? Thanks.
2007 CLK 550
Old Aug 2, 2014 | 09:52 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Correct - but the tape they use at the factory is pretty strong stuff. I think "flossing" it off is the best approach - you use floss or a similar cord to run between the spoiler and the trunk to saw through the adhesive.
Old Aug 3, 2014 | 03:00 PM
Fatz's Avatar
2008 clk550 - Navigator - Frontier
You will need thick floss or you can use fishing line. A wooden pencil, candy apple stick, or a piece of hard rubber or plastic about that size will be handy to put between the spoiler and trunk as you work your way from one end to the other. This keeps pressure on the spoiler tape and makes it easier to cut through the heated tape.
If you're going to paint and re-install, why not just paint it without removing it from the car?
Old Aug 3, 2014 | 03:18 PM
Louie D's Avatar
2015 E400 CAB, 2010 Jeep Compass, 2009 E350 Sedan
All of above you can also use a heat gun to slightly heat it up as you go. Its a tedious task my thumb was wore out rubbing the left over tape off.
Old Aug 3, 2014 | 08:42 PM
Fatz's Avatar
The Goo-Off or Goo-Gone gels work really well in easing the removal of the residual tape adhesive. Then a good wipe down with alcohol, a mild solution of dish washing liquid, and then plain water. When you see it without the diffuser and all cleaned up, you'll be tempted to leave it without a spoiler....
