Dipped Beam Left Malfunction
Old 09-29-2014, 02:15 PM
xsever's Avatar
2012 C300 4MATIC Sport
Hello everyone,
I drive a 2005 CLK 320 Coupe (german spec) with the Bi-Xenon option.
I am having a problem with the left-side xenon beam where sometimes it doesn't work. This happens right from the get go sometimes and sometimes I lose the light as I am driving.
The way to fix it is to disconnect the xenon module cable from the bulb, reconnect it, then switch the lights on.
When I fixed it the first time, I thought it was a loose connection because of road bumps or something but the problem keeps coming back yet the connection is solid.
What am I missing and what can be done? Is this common? Is it a SAM problem? Should I connect STAR when the light stops working and see what error codes I get or is it much simpler than that?
Please let me know.
Thank you,
Old 09-30-2014, 04:12 AM
DanielFD's Avatar
2007 BMW 550i
This is obviously not the cars fault. The driver of the car is the problem. Try changing the driver maybe?
Old 09-30-2014, 09:16 PM
lowpost's Avatar
2018 E43 | 2017 GLS450 | 2004 CLK 500
You may/will need to replace your headlight.
Old 10-01-2014, 01:08 AM
xsever's Avatar
I made some progress. It's something to do with a loose connection. I added a foam chunk as a pad to the circular dust cover and the light started working fine.
I'll test it for a day or two and make sure it's a final solution.
Quick Reply: Dipped Beam Left Malfunction
