SRS Light - 1 Malfunction
Did I break something or is this just a "latched" failure light?
What might I have broken?
If I broke the clock spring will a simple continuity check tell me this?
The Mercedes Part Center lists a clock spring but no price; what does this mean?
Is the clock spring separate from the steering angle sensor?
Does the "1 Malfunction" indicate that it is an active code, i.e a current fault?
I have read that ODB tools will not reset an SRS code - is this true?
Note: I also started the car while sitting in the passenger seat which I have heard can cause this light to come on.
Sorry for all the questions but any help would be appreciated.
I checked and the continuity seems good now. But it might have been bad the first time I started the car.
Do you know if the "1 Malfunction" means that there is a current fault?
Or also does it say that with a latched fault?
So I would have to say it is an active fault.
Are you getting the SRS yellow dash light on also.
When you scroll up when you have the "1 malfunction" text, does it give you any more info?
I was hoping there was a way to tell whether I have corrected the fault before I take it in to the shop. I would like to fix as much of this myself as I can.
It could possibly be a loose wire somewhere... best of luck!
