ESP Problem
Old Oct 26, 2014 | 07:53 PM
BS-Kai's Avatar
w209 w163 w211
ESP Problem
Hello, I have the problem, I have a CLK rebuilt 200k on CLK 500
when I do start at full throttle and then brake immediately electronics control to idle
I'd like a burnout but that will not do, even if I esp off and press the triangle in the speedometer will light goes nothing! what can it be? I esp installed by clk 500! I need to install an AMG esp?
thanks for all information, sorry for my english! thanks
Old Oct 26, 2014 | 09:45 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Even with ESP off via the dash button, it's still partially active. Try using "dyno mode" - search the forum and you'll find instructions to enable that which will completely disable ESP.
Old Oct 27, 2014 | 04:55 AM
BS-Kai's Avatar
w209 w163 w211
Dyno Mode I know
trouble, I can not fully power start at traffic light then comes esp control
Old Oct 27, 2014 | 11:42 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
So even in Dyno Mode ESP is intervening? In my CLK550, if I start off the line at full throttle, ESP will kick in and kill all the fun by throttling the engine back. If I turn it off with the dash switch, I can do a full-throttle start, but it's still using the brakes to prevent some wheelspin, so no "burnouts". Only in Dyno Mode can you do a burnout. I have hear (via Glyn) that this can actually kill the power steering pump. I can't figure out how or why, but Glyn is a trustworthy source, so there must be something to that.
