Fuel Problem
A week ago I had a hard start like it was not getting gas. I shut the car off and restarted and it ran fine.
Today the call just died. I can crank but the car will not start. I took the air filter off and sprayed a little gas in the throttle body and the car started for just a second.
I believe it’s the fuel pump but have no idea for sure or where it’s located. I would appreciate any help from this forum
Thank you in advance
This was my experience of a failed CPS. I was driving one day and the engine died all of a sudden. I stopped the car and attempted to start the car. The car would crank but did not start.
I waited a few minutes; cranked again and it did start. I let it idle for a few minutes and it died again all by itself.
I repeated this a few times and I finally called MB roadside assistant.
The tech knew right away it was the CPS and it took him only 15-20 minutes to replace it.
