CLK HEADREST SWITCH
Old Mar 15, 2015 | 10:33 PM
COOPERDB's Avatar
NB8 PARACHUTE
CLK HEADREST SWITCH
I did a search and found conflicting results
Will the headrests from a 2013 ML
fit and work in a 2003 CLK 500
Thanking Rodney (most likely) in advance
Thank-You
D.B.
Old Mar 15, 2015 | 11:12 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Are you talking about the switch panel on the door, or the headrest itself? My copy of EPC only cover through MY2011 so I can't check that 2013, but the headrest switches part number for the W209 is a "209" specific part number. If you are talking about the actual headrest, then I suspect it will fit. I assume the ML's headrests use the same spacing as the W209 and have the same active restraint mechanism. If all that matches, then I don't see why not.
Old Mar 16, 2015 | 12:30 AM
COOPERDB's Avatar
NB8 PARACHUTE
My bad
I was asking about the headrests being changed
from the ML to the CLK
The post holes are the same distance
Thank-You Rodney
D.B.
Old Mar 16, 2015 | 09:58 PM
Lfixer1's Avatar
2001 ML 320
ML 350 BALANCE SHAFT PROBLEM
Thank you for your response. I don't know, I looked at our engine and that was the serial number stamped on it. Our vin# is 4JGBB86E38A306017. Also, I have attached a link from a lawsuit about the balance shaft gears. I a bit confused now, the article lists 2008 ml350's, but your saying the problem was corrected prior to our model year. Please advice... thank you.
http://http://classactionlawsuitsint...-m273-engines/
Old Mar 16, 2015 | 11:09 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
You probably want to move this to a more appropriate thread regarding balance shaft issues.
