Wood Trim on Glove box
Old Feb 29, 2004 | 04:36 PM
opusnron's Avatar
2000 SLK, 2003 CLK
On the ForMyMercedes site link they say "Ash Wood Illustrated" with a part number of 209 2017. They also have a "Burl Wood" with a part number of 209 2015. My 209 is "Burl Walnut Wood and I'm wondering if their "Burl Wood" is the same as my Burl Walnut Wood. Cliffybabe - what style is your wood?
Old Feb 29, 2004 | 07:03 PM
cliffybabe's Avatar
CLK Coupe 200 Komp 53 Plate
opusnron
i belive mine is the same as yours im gonna see if they can supply pic of this part
Neil
Old Feb 29, 2004 | 07:15 PM
cliffybabe's Avatar
Here a pic of my trim, what one do u think it is?
Old Feb 29, 2004 | 08:19 PM
sjclk's Avatar
2004 CLK 320 Cabriolet
opusnron,
I order mine from formymercedes.com and just received it. I haven't had a chance to install it yet. I have the cahrcoal interior with the burl walnut trim too. Will post pics as soon as I can.
cliffybabe,
I talked with the guy when I ordered mine and he said he could match it. I sent him a pic of my trim and he said no problem but it would take him a week to get it.
Here's a pic of my interior as it is right now.
I just recieved mine on friday I will try to install it tonight and post pics.
sjclk
Old Feb 29, 2004 | 08:54 PM
opusnron's Avatar
2000 SLK, 2003 CLK
My interior is the same color as SJCLK, cliffybabe's appears lighter in color. Will be waiting for SJCLK's pics and also how it was to install. I'm wondering if it's a "stick-on" does it stick out!
Old Mar 1, 2004 | 03:44 AM
DTMCLK's Avatar
GF
Hi All,
Any one has Avantgard trim(chrome and aluminium ellypta) on Glove box? where can we order one?
Thanks all
DTMCLK
Old Mar 1, 2004 | 08:41 PM
  #32
sjclk's Avatar
Well I finally completed the install of the wood trim today and here are the results...
I think it looks pretty good. It was very easy to install but it took some time. I will post with a more detail explanation shortly.
sjclk
Old Mar 1, 2004 | 11:59 PM
  #33
opusnron's Avatar
2000 SLK, 2003 CLK
Lookin good sjclk - details, details!
Old Mar 2, 2004 | 12:44 AM
  #34
kaiju's Avatar
2010 ML350 CDI AMG Sports, BMW e92 335i (sold), CLK240 Avantgarde (sold)
yes, that's very nice, but what about the Avantgarde owners any idea what part number it is?
BTW, was that an aftermarket part?
Nice stereo there too, was that a standard one? wished mine were like that
Cheers,
Ho
Old Mar 2, 2004 | 11:54 AM
  #35
sirees01's Avatar
CL 600 Bi-Turbo
sjclk
that looks good m8.
I have a clk cabrio coming in April & I want this glovebox trim also.
How good a match is it to the Mercedes factory trim ?
Old Mar 2, 2004 | 12:10 PM
  #36
sjclk's Avatar
opusnron here is what's involved in doing the wood trim.
1. I removed the the handle from the glovebox door. Its attached with four screws from the back. You'll need a Tork type screwdriver to remove the screws.
2. I seperated the leather covered plasitc insert from the metal handle frame. I started at one end and pried with my fingers but that didn't work to good so I used a small jewelers screwdriver. I gently pried between the plastic insert and the handle until the plactic popped up and then worked my way down the length of the handle.
3. After I had removed the insert I had to clean the residue of the glue they use off the handle. I used some stuff called Goof Off to do this. After that I wiped the handle down with glass cleaner and a dry cloth,
4. Next I installed the wood trim insert which is a wood veneer on a plastic backing. It comes with a double sticky adhesive strip on the back. I removed that paper on the adhesive, aligned the piece on the metal handle and pressed it on. Once you press it down you won't have much room for corrections so you have to make sure thats how you want it. Altough it does come with a tube of glue from the manufacturer but takes 3hrs to set. After I had the wood insert in place I used some rubber bands and wrapped them around the ends and the middle of the handle for about an hour.
5. Lastly I installed the handle back on the glovebox door.
It very simple and I could have had it done that first night except I did not have anything that was working to remove the glue residue when I removed the black insert. Went to Homey depot the next day and got the goof off.
kaiju,
Sorry I don't know of a place to get the avantgrade trim piece. Here in the states they don't offeer the avantgarde trim package so I'm not sure what it even looks like. If you could post a pic that be great.
The stereo is the stock unit.
cliffybabe,
You might try here for the part. It will probably easier for you shipping wise since your in the UK.
If anyone has anymore questions just let me know and I'll try to answer them.
sjclk
Old Mar 2, 2004 | 04:18 PM
  #37
opusnron's Avatar
2000 SLK, 2003 CLK
So, if I understand you correctly, you removed what is currently on the handle and replaced it with the wood rather than sticking the wood directly on top of what is currently there and you didn't use the supplied glue.
Old Mar 2, 2004 | 09:47 PM
  #38
kaiju's Avatar
kaiju,
sjclk [/B]
These are the same trim we have on the Avantgarde, pic is an SL, that's the best shot I could find.
Cheers,
Ho
Old Mar 3, 2004 | 01:10 AM
  #39
sjclk's Avatar
opusnron,
Yes that is correct. you remove the old insert and install the wood insert. It is not a stick on piece that is applied on top of what is already there. The wood insert had the double sticky tape but also include a tube of glue.
kaiju,
I don't see a picture. Please post it again.
sirees01,
Its a very good match to the Mercedes factory trim
sjclk
Old Mar 3, 2004 | 06:31 PM
  #40
kaiju's Avatar
opusnron,
kaiju,
sjclk
Damn Imagestation! I will need to email the pic to you, please PM your email to me.
Ho.
Old Mar 3, 2004 | 07:06 PM
  #41
cliffybabe's Avatar
Ho.
email it to me ill post it 4 ya, im still having prob's finding uk or europe supplier maybe ill have to import the part
Old Mar 3, 2004 | 09:24 PM
  #42
kaiju's Avatar
done, its in your email now.
Old Mar 4, 2004 | 12:15 AM
  #43
opusnron's Avatar
2000 SLK, 2003 CLK
I ordered the insert from formymercedes, should be in next week. It costs the same as a new (regular) handle from Mercedes ($60) Asked for the cost of the original in case I screw up the install since I'm not known as "Mr Mechanic"
Old Mar 4, 2004 | 09:10 AM
  #44
cliffybabe's Avatar
Here's your Pic
regards
Neil
Old Mar 4, 2004 | 02:06 PM
  #45
sjclk's Avatar
Don't worry opusnron its's very easy. If you need help let me know.
kaiju,
I've never seen that trim before but I will keep an eye out for it.
originally posted by sjclk
cliffybabe,
sjclk
Old Mar 10, 2004 | 03:39 AM
  #46
sirees01's Avatar
CL 600 Bi-Turbo
UK Owners
Just received an e-mail from Schätz-Tuning GmbH
This trim can be bought here so i'm told.
Special Vehicle Services Ltd.
West Druxton
St. Giles on the Heath
PL15 9SX Near Launceston, Cornwall
Tel. +44 087 024 066 57
Fax: +44 156 677 722 1
email: info@specialvehicle.co.uk
Old Mar 10, 2004 | 04:00 AM
  #47
cliffybabe's Avatar
Originally posted by sirees01
UK Owners
West Druxton
Cheers man thats wicked ill be ringing them today.
Old Mar 15, 2004 | 12:22 PM
  #48
sirees01's Avatar
CL 600 Bi-Turbo
I got mine today from Jerry
All I need now is a clk cab to put it on.
Can`t wait for April/May to come
1 trim no car, I must be mad.
Old Mar 15, 2004 | 12:29 PM
  #49
cliffybabe's Avatar
How much did u pay i tried calling but with no joy, can u help, what dash will u have?
Neil
Old Mar 16, 2004 | 08:31 AM
  #50
sirees01's Avatar
CL 600 Bi-Turbo
Description : 209 2015 Burl Wood Glove Box Trim $59, Global Express $28.75
Amount : 87.75 (USD)
Contact Jerry at www.ForMyMercedes.com very helpful guy & speedy delivery all for about £50
My order is Tanzanite blue/blue hood/sand leather/std walnut trim.
Hope this help cliffybabe
