So I was trying to see if my HK subwoofer was blown, because at times at heavy bass, it would have a slight buzzing noise.
held down by 4 10MM nuts
When I stick my finger in the output hole, it would stop. Very strange.
So I was prepared to remove the sub and send it into a speaker repair shop in OC. They fixed my 911's JVC sub when I blew it putting too much signal input to it Eh, it was only $25 vs $400 for a new one
NOTE, you must remove the seats to get to the 10MM nuts in the back. The seat's mount covers require you to push a screw drive up the hole to release the plastic clip to expose the 13MM nuts.
So I took out the billion screws and carefully pryed the cover off. Checked the sub, no tears wtf???
Looked for broken or loos housing parts, Nada
Looked at the cover and the output hole. VOILA! the tube is about 8-9 inches long so with my fingers I would have never felt it.
Some moron put a picture of their fugly dog inside the tube.
Reassembled, raise the bass to 10. Please some heavy **** bass tunes. BUZZ BE GONE
