Reset the TPMS warning?
Old Jun 4, 2015 | 11:46 AM
andyncLI's Avatar
2018 GLA45 AMG, 2010 S63 AMG
I had 2 new tires put on front wheels and sure enough now the TPMS low pressure warning came up. What are the steps to reset it?
Old Jun 5, 2015 | 01:45 AM
DanielFD's Avatar
2007 BMW 550i
open up the Kilometer/mile display on the MFD then cycle inside that menu until you reach the tire pressure monitor then the screen will tell you to press + to reactivate the TPMS, so go ahead and press + and wait a few seconds then the MFD will tell you "TPMS Reactivated!" now please note the "!" because that's Mercedes's way of mocking us for the terrible way of resetting the system and making us second guess that its reset.
Old Jun 5, 2015 | 08:46 AM
Yidney's Avatar
2008 CLK550 Cab
But first make sure it needs to be reset. The people who put your tires on may have simply inflated the tires to less than normal, and the system is simply telling you that. Resetting it does not simply turn off the light, it makes whatever pressure is in your tires at the moment the new normal. You don't want that. Inflate them correctly and then reset it.
Old Jun 5, 2015 | 09:42 AM
andyncLI's Avatar
Good point to check the pressure before resetting it. Did find the reset option in Tire Pressure page under Settings, and need to hold the reset button to trigger the reset.
Old Jun 6, 2015 | 01:52 AM
DanielFD's Avatar
2007 BMW 550i
ah i'm guessing you have hardware TPMS. did u notice the sensors when you replaced the tires?
