air condition service
Old Jun 14, 2015 | 08:56 PM
tl1000r1's Avatar
2003 clk 500 amg
I owned the car for 3 yrs ....air condition is now blowing warm air.....still cool on passenger side though....I'm hoping it's just a recharge or lack of Freon....already put $2500 dollars in for maintenance a lot of it preventative....Any thoughts would be appreciated.
Old Jun 15, 2015 | 02:00 AM
DanielFD's Avatar
2007 BMW 550i
It is possible that its just a lack of Freon, and it could be much simpler then that. Try holding the recirc button and the front defrost button with the car on for 5 seconds, they should start blinking(that will start a reset of flap position and reset of the AC system). the reset solved the same problem i had with my AC system once.
Old Jun 15, 2015 | 02:01 AM
DanielFD's Avatar
2007 BMW 550i
oh and btw if they dont stop blinking after 30 seconds or so then there's probably a problem with the flaps or something else in the system.
Old Jun 15, 2015 | 07:43 AM
jdhiller's Avatar
2004 clk500 cab
I have done this and it does work.
Old Jun 15, 2015 | 11:20 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Check the refrigerant levels. When it gets low, for some reason, the driver's side tends to stop cooling. Another thing I have heard is that SDS (Star Diagnosis) can do a recalibrate of the system that helps this problem.
Old Jun 16, 2015 | 07:33 AM
tl1000r1's Avatar
2003 clk 500 amg
Thanks a lot fellas.....I'll test 2day.
