Front control arm bushings
ADDED BONUS IS THE CONTROL ARM BUSHES ARE PRECISELY ADJUSTABLE FOR CAMBER AND THRUST ARM FOR CASTER (THERE IS ONLY TOE ADJUSTMENT OEM!)
CAMBER – Allows to actually change the tire contact angle, improving wear/traction/understeer/oversteer
CASTER –Resolves steering pull, increases steering response. With better turn in and high speed directional control, along with improved anti dive/lift under brake and acceleration.
K-MAC has been manufacturing suspension bushings for over 50 years. These (4) above front bushings are also the highest wearing. So the unique K-MAC patented replacements are designed to have twice the load bearing area and to eliminate the OEM air voided, oil filled bushings, yet still retain the 2 axis movement. Result is improved brake, traction and steering response.
Precise/ongoing adjustment capability – single wrench on car accurately (under load) direct on alignment rack.
Fixing it right the 1st time – resolving costly, premature inner edge tire wear and steering pull - the result of curb knock damage, altering suspension height, load carrying or fitting wide profile tires/wheels. No more ongoing visits to dealers or alignment shops or constantly changing tire brands.
For the rear – similar precisely adjustable bushings for Camber (the main lower control arm inner) and replacement bushings for extra Toe adjustment. Necessary to cater for the new Camber facility.
W209 Front – Camber and Caster #502216K $480
Rear– Camber (and extra Toe)- (01 – 5/04) #502026H $320
(6/04 – 09) #501926J $380
Current promotion for MB World members USA/Canada delivery - $30 one kit or $40 front and rear (normally $70 one kit, $80 front and rear). Can pay by Visa, MasterCard or PayPal.
See link for latest 2015 catalog Audi to Volvo – World’s largest range. http://K-mac.com/mercedes/
