Easy Exit/Entry System
For easy exit, the steeling wheel is supposed to go up and the driver seat is supposed to move back. For me, the steeling wheel goes up every time but for the seat. it works only sometimes I don't quite understand it but it seems that it has something to do with the memory seat.
Can someone please shred some lights on this?
I do not quite understand the easy exit/entry system of my 2004 CLK-320 coupe. I double-checked the multi-function display of the steeling wheel many times.
Try this. Move the seat more forward and then turn your car off, and see if it moves back for the easy exit.
I may be totally wrong, but try it out.
I noticed that the steering wheel will always move up but the seat will move back only occasionally. I noticed that it will work for a while and then if I move the seat front-ward or backward manually or by the memory setting, the easy-exit will not move the seat again.
The seat and steering wheel behave differently when I have the key in the ignition or just use the keyless go......can anyone shed light on this?
