PS0025 and engine Ping
Can someone tell me why after changing my cam position sensor I still get a check engine lite that comes on the goes away then comes on (every 100 miles or less).... no real biggie but also it pings allot more then before. Balance sensor is fine I did the manual check bit turning the fly wheel to 310 degrees. Then I make sure the stamps on the crank match up with the peek holes on the cyl heads.
( neat trick to see if your timing chain jump a tooth)
