Sirius
Old Nov 12, 2015 | 05:53 PM
BK627's Avatar
2007 CLK 350 Cab
Sirius
2007 clk 350 cab
I searched under the carpet to find the Sirius module and it looks like my car didn't come with it. Is it a lot of work to add Sirius to my car. I tried searching the forms and can't find much details on adding the Sirius module.
Old Nov 12, 2015 | 10:27 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The Sirius module is in the trunk. What happens when you press the SAT button on your radio?
Old Nov 13, 2015 | 12:12 AM
BK627's Avatar
2007 CLK 350 Cab
When I press sat it says aquiring signal, and it stay like that.
I meant to say I searched under the carpet in the trunk and could t find it.
Would it be too hard to buy one from eBay and instal it?
Old Nov 14, 2015 | 10:08 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
If it says acquiring signal, then you have a Sirius tuner installed, so it's either a bad one, or an antenna problem.
On the cabriolet, the tuner module is in the trunk, under the carpeted section between the back seat and the spare tire well. When you remove that carpet, you will find several electronic units. The Sirius tuner will be the one on the front right corner. I believe it's a black plastic housing - item #1 in this picture:
The antenna is in the trunk lid. Remove the carpet on it and it should be in the center - item #2 in this picture (note that item #3, which looks very similar, is the GPS/Teleaid/Phone antenna):
Old Nov 14, 2015 | 11:44 AM
BK627's Avatar
2007 CLK 350 Cab
Thanks for that reply! I was looking in the wrong spot for it. So yesterday I installed the navigation now when I press SAT it says call 888-539-7474 and on the cluster it says NO SAT.
I'll attach a picture also. Last time I tried calling Sirius they told me that If everything is connected I should receive the preview channel.
Old Nov 14, 2015 | 12:09 PM
BK627's Avatar
2007 CLK 350 Cab
I just got off the phone with Sirius they activated it and got it to work. Wish the first person I called knew what they were doing.
Thanks for your replies!
Old Nov 14, 2015 | 09:59 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Glad to hear you got it working! I can't drive without my Sirius radio.
Old Nov 16, 2015 | 04:40 PM
eteller's Avatar
2009 CLK 350
A little off topic but has anyone else found Sirrius does not sound as good as FM? Sounds like lots of compression going on or something.
Old Nov 17, 2015 | 10:01 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yes, Sirius is compressed. Some channels are worse than others. Most of the music channels are OK, but the talk and sports broadcasts are more compressed.
Old Dec 6, 2015 | 08:59 PM
fishndude's Avatar
Current: 2011 SL550 Previous: '07 CLK550 Cabriolet 1981 240D
I have had a Sirius subscription for about 3 years. There are several channels that I am not able to receive. I have always thought this was due to the age of the Sirius tuner. This year Sirius has Christmas music on channels 13 and 18. When it try to tune to these channels it says invalid channel, yet the display says I can get channels up to 223. Is anyone else able to pick up 13 and 18? If these channels were playing Christmas music the last couple of years then they worked fine.
Old Dec 6, 2015 | 11:24 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It's interesting that you mention that. My CLK550 has a Sirius tuner with an old "lifetime" subscription, activated by the original owner. I don't get channels 11-18, either. I've never bothered to call, since the subscription is not in my name and I figure they'd kill it. I do get channel updates periodically, so I think it may be a limitation of the tuner itself.
Old Dec 7, 2015 | 11:17 AM
fishndude's Avatar
Rodney,
Thanks. I was afraid of that. My wife and I have identical subscriptions and she drives a 2010 Enclave and gets a bunch of channels. They change periodically with the updates. I get the update signals, but do not see channel updates or new channels. I figured it may be a limitation of the tuner and I assume there is no way to upgrade the tuner?
Old Dec 7, 2015 | 11:08 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I have two very old portable "Sportster" radios subscribed and a Pioneer AVIC in the C240 with a subscription and all of those get these channels. I am guessing it's just a limitation of the MBZ module. ]Since you have an active, paid subscription, I'd suggest calling SXM and question them about it. I don't believe there is an updated tuner, but if there is, you'd have to buy it. I'd be interested to know what you find out.
Old Dec 10, 2015 | 11:01 AM
fishndude's Avatar
I spent about an hour on the phone with XM/Sirius yesterday. They told me that the specific model tuner in the CLK550 does not pick up "premium stations", which evidently 13 and 18 are. The age of the tuner doesn't matter, it is the model. They were not sure about replacing the tuner, they said I would either need to go to a stereo shop or dealer. As a work around, they gave me a free internet subscription, so I can stream the stations from my phone thru the Bluetooth system. Not ideal, but I'll take the free subscription. I have unlimited data on my phone, so it isn't a problem. I am not sure you can even replace just the factory installed Sirius tuner anyway. I thought you would need to replace the entire sound system. I don't think I want to invest a ton of money just to get a few extra stations.
Old Dec 10, 2015 | 09:36 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The Sirius tuner is a separate, individually-replaceable part, but I doubt a new one would do any good. I'm just glad that my subscription is "Free". Many original purchasers took advantage of the "lifetime" subscription. MBZ gave them one year free, and Sirius would apply the value of that year to the cost of the lifetime, so for less than $300, you got lifetime.
Old Dec 13, 2015 | 01:08 PM
Airmousam's Avatar
2010 E550 4M P2 Distronic, CLK550 Cab P2
Yup, my 2010 E gets more channels and I can't get the Xmas stations either in the clk
