CLK 200 2006 - Pointers?
I hope you dont mind me joining the forum as Im considering buying a Mercedes CLK 200 from Japan. ( I am based in Botswana)
Currently driving a VW GTI.
The car has 53K in the clock and both keys.
I would like to know the following if anybody could assist:
1.) Im guessing the 60K service would be a major one. What is/should be changed out?
2.)Are the auto gearboxes pretty solid on these vehicles ?
3.) What are the parts that are known to give issues on this vehicle?
I will have to replace the stereo as my Japanese is not great
Any advice would be appreciated. I am reading through the threads but anything extra would help.
Cheers
If you will have the dealer do you service, it will be very expensive. here in the US< most dealers charge around $300 for a standard oil change + fluid top-off and inspection service. Other things are extra and can easily run over $1000 when you add in things like transmission service, brake fluid changes, spark plugs, etc. You download the maintenance manual from mbus.com, "owner's section' to see what the recommended service intervals are. This won't cover the C200 (iit was not sold here), but if it's the Kompressor, just check the MY2002 C230 - it's the same engine.
Thanks for the reply
It is definitely the C200 Kompressor 1.8L . Surely a petrol variant is more reliable and cheaper spares wise then a diesel??
This is not a local model here either so thats why I was hoping some forum people know more about the vehicle. Trans and Engine reliability being my main concerns!
Cheers
