Bose Amp Wiring
Bose Amp Wiring
Hello Everyone , I need the pin layout for bose amp harness . I searched but I found a few types not sure what works for my car . its a 2004 clk pre face lift. Thanks in advance...
If you are tapping into the analog speaker wiring there, then the colors are the same as they for the radio wiring harness:
http://benzbits.com/Audio10Pinouts.pdf
Tweeters and woofers are tied together on each channel and are not driven independently. There's a filter for the tweeter to operate properly. Although I'm certain they exist, I have yet to see a factory system set up with dedicated channels- each one I have seen used a basic filter or crossover. Would be nice if they did though! I'm assuming if you're adding an amp that you're also swapping speakers? The Bose speakers are very low quality and are at extremely odd impedance's.
Yes I am replacing the front speaker with components . 2 way for the rear speakers and I found a small sub that I am trying to fit in the original Bose box . Thank you for the help I will update with a diy
